I am trying to use the minimal Interface certification that I want to swap out the standard High speed interface for in the 'Interface' Metric Family.
But it isn't listed in the Priority listing of all the vendor certifications under it. How do I add it so I can use it.
High Speed Interface (Exclusive) Vendor Cert not appearing in Vendor Certification Priorities list
Dx NetOps Performance Management any version
Details are in the following documentation
https://techdocs.broadcom.com/us/en/ca-enterprise-software/it-operations-management/performance-management/3-7/building/self-certification/manage-vendor-certification-priorities.html
