Problem parsing payloads RA.JMS RECEIVER job.
Article ID: 192236
CA Automic Workload Automation - Automation Engine
In a RA.JMS Receiver job a JSON payload is received but the parsing with Jsonpath is not working.
The variable that is using in the Postscript remains empty while the Jsonpath tests correctly.
Release : 2.x
Component : RA JMS
In the Job Report we find line like this:
2020-04-29 10:05:35             pool-1-thread-4: Receiver: message: SolBytesMessage={ JMSCorrelationID:0008467681,...
2020-04-29 10:05:35             Received: 1 ID:10.117.68.12181221719ce8c5280:4696 SolBytesMessage
This indicate that the message type is BytesMessage instead of TextMessage.
The payload received by the Receiver job needs to be plain text (TextMessage) for the parsing to work.
