The format of the application.properties must be in the following format:
server.ssl.key-store=mykeystore.jks
and the keystore that you use (mykeystore.jks) must be placed in the following directories:
- Windows -> ......\Analytics\backend\
- Linux/Unix -> ...../Analytics/backend/
