"Error *LIBL not found" with XCOM for AS/400
Article ID: 192073
Updated On: 07-29-2024
XCOM Data Transport XCOM - SUPPORT
On our Production server, the XCOM file transfer gets rejected with error *LIBL not found. The job log is below.
It worked last night and worked this morning and after that when we try now it failed.
 Message ID . . . . . . :   CPF1269       Severity . . . . . . . :   00
 Message type . . . . . :   Information
 Date sent  . . . . . . :   20/06/02      Time sent  . . . . . . :   13:04:53
 Message . . . . :   Program start request received on communications device
   XCOMCT1F was rejected with reason codes 605, 1518.
 Cause . . . . . :   The program start request was rejected in job
   216556/VETRI/XCOMCT1F. The device belongs to remote location XCOMCT1F. If
   the device is an advanced program-to-program communications (APPC) device,
   the program start request was received on mode XCOM16K with unit-of-work
   identifier FIDD.UNISEN08-D8029D764DEC-0001. The first reason code means:
   Program was not found in the library specified. The second reason code
   means: Problem phase program not found in QSSP.
 Recovery  . . . :   See the job log for more information about the problem.
XCOM™ Data Transport® for AS/400 i5/OS
This message is due to the device being allocated to the wrong subsystem. To correct, this vary the device off and back on to be allocated to the correct subsystem. You should also check the iSeries QCMN subsystem to determine if the device was allocated to it.
Check the communication entries for the XCOM subsystem XCOM2SBS by doing a:
DSPSBSD XCOM2SBS
from the command line. Next select the option for communication entries. You should have something like the following:
Device            Mode              Job Description      Library          User          Max active
XCOMDEV    XCOMMODE     XCOM                 XCOM2        XCOM       *NOMAX
where XCOMDEV is the device used for XCOM transfers, and XCOM2 is the library where XCOM is installed. Make sure the user is XCOM as that is where the security violation comes from.
This problem is a result of the device being allocated to QCMN which has a default user of *SYS instead of XCOM. XCOM does not recognize this, therefore the security violation results.
If the communication entry is correct already, then you simply need to vary the device off and back on again to make sure the device is allocated to XCOM2SBS. The device can be varied on/off with the
WRKCFGSTS *DEV XCOMDEV
Once device is varied off, start XCOM2SBS using
STRSBS XCOM2SBS
from the command line. Once XCOM2SBS is active, use
to vary the device on. Now device should be allocated to XCOM2SBS.
Additional message in the joblog:
CPC1116 Message . . . . :   CPC1116 Program XCOMSEND in library *LIBL not found.
