Problems with ACL/E for signing on to TSO
Article ID: 191725
TPX - Session Management
A startup ACL defined at  PROFILE level that should fill in Userid and Password on the sign Session screen seems to fill in only the userid, causing a consequent authorization error.
Release : 5.4
Component : CA-TPX for OS/390
For some reason, the startup ACL at USER Session Level field, contains blank characters instead of the default value that is underscores only ( ( i.e Startup ACL : ________ ).
This override the value defined at PROFILE LEVEL for the Startup ACL, and was causing the error.
The startup ACL at USER Session Level field, when not specified, needs to be filled in with UNDERSCORE characters ( i.e  Startup ACL : ________ )
This will avoid the override of the Profile setting.
