CA IT Asset ManagerCA IT Asset Manager Asset Portfolio ManagementCA Software Asset Manager (CA SAM)ASSET PORTFOLIO MGMT- SERVER
Problem with check installation. During the install of SAM, during Check Installation, an error may present that states in the check_installation log that Parallel Processing or Parallelization check has failed:
2020-05-07 10:43:54 26 MB INFO start requirements for parallel processing 2020-05-07 10:43:54 26 MB INFO mode for inter-process communication: filesystem 2020-05-07 10:44:59 26 MB ERROR asp_retry->throw_non_transient_exception(): failed. error: error code: [500001], error message: [producer->assert_handshake(): failed. error: Handshake with consumers failed because only 0 of 2 consumers did send an acknowledgement]
Release : 4.4
Component : CA SOFTWARE ASSET MANAGER
The given instance did not have any DB parameters defined in the config.ini
In all instances, a backend database needs to be established for the Check Install to run and pass on the Parallel Processing or Parallelization check. One can either create a temporary/dummy database or have the actual database content from an existing SAM instance imported to a database for the given SAM install to work against.
See also the following tech doc for recommended instructions to install SAM:
