We have a P2P environment set up and all is fine with that.
The system is DR eligible. The customer wanted to access these P2P tapes to see if they are recoverable. Since this would not be a P2P environment, they set it up as a VTAPE classic environment.
The VTAPE instance comes up ok, the drives are online and the catalog looks good, however, the customer's batch job goes into device allocation looking for a tape drive.
Looking for some advice.
Release : 12.6
Component : CA VTAPE
The VTDRIVE definitions of the DR system which is attempting to read the 'remotely' created volumes does not define any remote drives via the 'OnlineRemote' / 'OfflineRemote' VTDRIVE parmlib parameters. Also, this DR system is not configured as a 'P2P' system, but rather as if it is not using P2P.
To allow read access to P2P/Remote volumes on a DR system, the system will need to be configured as if it is a P2P system (even though there is no intent to create new virtual volume data to be transmitted to a remote system), and the VTDRIVE definitions of the DR system will need to include device definitions for the 'remote' drives, as Vtape uses these drives when it recognizes a 'remote' volume that is to be mounted (i.e., Vtape will NOT use the 'local' drive definitions to read a 'remote' volume, and if no remote addresses are defined and online, the job will hang waiting for allocation).
An example of the symptoms of this problem: ==================================
10.53.09 J0321072 IEF244I A058775I STEP010 - UNABLE TO ALLOCATE 1 UNIT(S) 129 129 AT LEAST 1 OFFLINE UNIT(S) NEEDED. 10.53.09 J0321072 *IEF877E A058775I NEEDS 1 UNIT(S) 130 130 FOR STEP010 SYSUT1 130 FOR VOLUME AC4790 130 OFFLINE, NOT ACCESSIBLE 130 0900-09BF 09C8-09FF 0B00-0B9F 0BB0-0BFF
An example of the VTDRIVE definitions causing this problem: ===============================================
<VirtualDeviceList> initialized from member VT8DEVT Device CU Initial State --------- -- --------------- 0840 1 ChpidDeviceList 09C0-09C7 1 Offline 0840 2 ChpidDeviceList 0840 2 ChpidDeviceList 09C8-09CF 2 Offline
An example of corrected VTDRIVE definitions allowing successful processing (also, the 'PeerToPeerOptions' and 'PeerToPeerRemotes' members will also need to be active): ========================================================================================================================================
