C1G0296W THE OUTPUT DATASET LRECL OF (31996), IS LESS THAN THE TYPE DEFINITION OF (32000).
Failing Endevor Processor step is:
//CONWRITE EXEC PGM=CONWRITE,PARM='EXPINCL(N)',MAXRC=0
//ELMOUT DD DSN=&HTMLLIB(&C1ELEMENT),DISP=SHR,
// MONITOR=&MONITOR,FOOTPRNT=CREATE
With HTMLLIB='ZX.PROD.DLOP.HTML'
The Endevor Type is defined as follows:
DESCRIPTION: ===> HTML DOCUMENTS
UPDATED: 11JAN18 11:35 BY xxxx
----------------- ELEMENT OPTIONS -------------------
DELTA FORMAT(F/R/I/L) ===> R SOURCE LEN ===> 32000 ELE RECFM(N/F/V) ===> V
COMPRESS/ENCRYPT(Y/N) ===> Y COMPARE FROM ===> 1 DFLT PROC ===> HTML
AUTO CONSOL (Y/N) ===> Y COMPARE TO ===> 32000 LANGUAGE ===> DATA
CONSOL AT LVL ===> 20 REGRESSION ===> 75 PV/LB LANG ===> DATA
LVLS TO CONSOL ===> 18 REG SEV(I/W/C/E) ===> W DATA FORMAT(T/B) ===> T
USS RECFM(COMP/CR/CRLF/CRNL/F/LF/NL/V) ===> NL FILE EXT ===>
----------------- COMPONENT LIST OPTIONS ------------------
FWD/REV DELTA(F/R) ===> R AUTO CONSOL (Y/N) Y CONSOL AT LVL 96
LVLS TO CONSOL 25
------------------------- LIBRARIES -----------------------
BASE/IMAGE LIBRARY ===> ZFLV.&C1STAGE..&C1SYSTEM..BASE
DELTA LIBRARY ===> ZFLV.&C1STAGE..&C1SYSTEM..DELTA
INCLUDE LIBRARY ===>
SOURCE O/P LIBRARY ===>
EXPAND INCLUDES(Y/N) ===> N
Release : 18.1
Component : CA Endevor Software Change Manager
The message C1G0296W is expected. For all datasets with RECFM=V or VB, the LRECL attribute is 4 bytes larger that the maximum record length that can be written to the file.
The message C1G0296W is misleading.
C1G0296W THE OUTPUT DATASET LRECL OF (31992) IS LESS THAN THE TYPE DEFINITION.
It should say 'record length' instead of LRECL.
C1G0296W THE OUTPUT DATASET RECORD LENGTH OF (31992) IS LESS THAN THE TYPE DEFINITION.
IBM wants a RDW (Record Descriptor Word) of 4 bytes for all records that have VB. That means the LRECL has to be 4 bytes larger then the actual record length. Also the BLKSIZE has to be LRECL + 4 bytes as well when dataset is VB.
