"CHASSIS DOWN" and "BLADE STATUS UNKNOWN" alarms on Cisco 2960x device models in Spectrum
Article ID: 190935
Spectrum
"CHASSIS DOWN" and "BLADE STATUS UNKNOWN" alarms on Cisco 2960x device models in Spectrum although these devices are not chassis devices
Release : Any
Component : Spectrum Core / SpectroSERVER
Although these device are not switches, they do support the Entity mib. Spectrum uses the Entity mib for chassis management.
To disable the creation of the "CHASSIS DOWN" and "BLADE STATUS UNKNOWN" alarms on Cisco 2960x device model:
1. Log into OneClick as an ADMIN user
2. Find and select the Cisco 2960x device model
3. Click on the Attributes tab
4. Find and select the EnableEntityModuleModeling attribute id 0x12ef5 and set the value to No
5. Right mouse click on the model and select Reconfiguration -> Reconfigure Model
6. Right mouse click on the model and select Reconfiguration -> Rediscover SNMP MIBs
Please reference the "Support for Chassis Devices" section of the documentation for more information.
