Client Automation - Difference between lsm -e and dsmuninst_bg -bg ca-dsm
Article ID: 190823
CA Client Automation - IT Client Manager
What is the difference between below commands:
lsm -e
and
Client Automation - All versions
The commands
lsm -e ca-dsm -s
and
could be used to uninstall ITCM agent silently.
Script dsmuninst_bg executes command "lsm -e ca-dsm -s"
This script does also some verification before and after uninstallation.
In uninstallation procedure of SD packages for Linux agent, following script is executed :
$CA_ITRM_BASEDIR/scripts/dsmuninst_bg -bg ca-dsm
Example :
So these 2 commands could be used to uninstall ITCM agent as they do mainly the same thing.
Feedback
thumb_up
Yes
thumb_down
No
