When configuring the ciphers suites in the ssl listen port settings, I noticed that the order of the ciphers does not influence the order in which they are presented in an SSL handshake.
This is contrary to what I have read on the docops:
Release : 10.0
Component : API GATEWAY
This is a known limitation which will be addressed in CR1 for GW 10
Thiss is planned as part of some other works on tls 1.3 and secure ciphers for GW 10 CR1 .
