CA Infrastructure ManagementCA Performance Management - Usage and AdministrationDX NetOps
Can obtain interface ID from DA, but when used to get information from via url api this doesn't line up. How do we figure out what the api interface id is so a url can be crafted to pull data?
Release : 3.7
Component : IM Reporting / Admin / Configuration
Go to Inventory -> Interfaces -> and pull up the interface page for that interface the last field in the URL in the browser will show the interface id.
