.I am seeing discrepancies in reporting with Power BI OData and Jasper soft reports.
When compare Power-bi Odata and information does not match for the same resource and month. It will be way off, checked the logic in the power bi script and it looks good, and has historically worked for the last year.
Release : 15.7
Component : CA PPM SAAS APPLICATION
