Set default values for WIP Class and Investment Class on Project
Article ID: 189958
Clarity PPM On PremiseClarity PPM SaaSClarity FedRAMP
I have all the Financial Management Defaults set, but when I create a project, WIP Class and Investment Class don't populate. We are then having nulls in the PAC_MNT_PROJECTS table
Release : All Supported Clarity releases
The Financial Management Defaults does not work to copy WIP Class and Investment Class to the Projects.
For Project you will have to enter a Default value via Studio on the Object - Attribute for both WIP Class and Investment Class. This will work well and avoid you from having nulls.
To correct the null values now you will either have to use XOG or a SQL update statement (which is a customization).
