Using the SQL feature of Datacom to determine how long the Multi-User Facility (called MUF) has been running.
Article ID: 18992
Datacom DATACOM - AD Common Components and Services for z/OS
How to use the SQL feature of Datacom to determine how long the MUF has been running.  This will help to determine availability and other reporting.
The MUF start time and the current time are available from the Datacom/DB Datacom System Tables, and can be reported using a simple SQL query:
SELECT MUF_NAME,
       DATE(BEGIN_TIME)       AS BEGDATE,
       TIME(BEGIN_TIME)       AS BEGTIME,
       DATE(CURRENT_DATETIME) AS CURDATE,
       TIME(CURRENT_DATETIME) AS CURTIME,
  FROM MUF_SYSTEM_STATS;
This will produce a simple report of the start date and time, and the current date and time. However, since BEGIN_TIME and CURRENT_DATETIME are both timestamp fields, there is currently no capability to subtract timestamps to produce an execution time.
In order to produce a comprehensive report showing the start time, current time, and execution duration, a more complex query can be used:
-- .5...10....5...20....5...30....5...40....5...50....5...60....5...70..
SELECT
 MUF_NAME,
 CHAR(DATE(BEGIN_TIME))  || ' @ ' ||  CHAR(TIME(BEGIN_TIME))
                                     AS "MUF START TIME",
 CHAR(DATE(CURRENT_DATETIME)) || ' @ ' || CHAR(TIME(CURRENT_DATETIME))
                                     AS "CURRENT TIME",
 SUBSTR(DIGITS(
    CASE WHEN TIME(CURRENT_DATETIME) < TIME(BEGIN_TIME)
         THEN DATE(CURRENT_DATETIME) - DATE(BEGIN_TIME) - 1
         ELSE DATE(CURRENT_DATETIME) - DATE(BEGIN_TIME)
    END),7) || 'D - '
 SUBSTR(DIGITS(
         THEN (HOUR(TIME('24.00.00') -
                   (TIME(BEGIN_TIME) - TIME(CURRENT_DATETIME))))
         ELSE (HOUR(TIME(CURRENT_DATETIME)   - TIME(BEGIN_TIME)))
    END),9) || 'H '
 SUBSTR(DIGITS(
         THEN (MINUTE(TIME('24.00.00') -
         ELSE (MINUTE(TIME(CURRENT_DATETIME) - TIME(BEGIN_TIME)))
    END),9) || 'M '
 SUBSTR(DIGITS(
         THEN (SECOND(TIME('24.00.00') -
         ELSE (SECOND(TIME(CURRENT_DATETIME) - TIME(BEGIN_TIME)))
    END),9) || 'S'                   AS "MUF ELAPSED TIME"
FROM SYSADM.MUF_SYSTEMS_STATS;
