Two microgateway containers are processing requests from an API Gateway.
When one of the microgateways was stopped by the stop command, the API Gateway received 404 response and couldn't detect the termination of the microgateway for several seconds.
On the other hand, the API Gateway detected the failure of another microgateway immediately when the microgateway container process was killed.
Are they expected behaviors?
Release : 1.0
Component : Microgateway
