DCD2534E DCEKEY length out of range, Max=230, Actual=24 Starting The Data Content Discovery DCDCONTL Started Task
Article ID: 188705
Feedback
Subscribe
Show More
Show Less
On startup of DCDCONTL. the following error is seen in the log:
DCD2533I DCD Controller - ESM Callable Svc Req=R_dcekey-get SAFRC=0 RC=8 RSN=20 DCD2534E DCD Controller - DCEKEY length out of range, Max=230, Actual=24
Release : 3.0
Component : CA DATA CONTENT DISCOVERY
If not using the default of DCDCONTL for the DCDCONTL started task ID, in the FEYDCEKP job, ensure the value of 'DCEKEY_DONOR_USERID=', is the same value specified in the FEYRACF Job when creating the DCE Profile Record for the DCDCONTL started task. Also, edit the following members: OEM.CADCD.V30.CFEYOPTN(FEYQPARM) OEM.CADCD.V30.CFEYOPTN(FEYQPDCM) and change the following: DCEDUSR(DCDCONTL) to DCEDUSR(xxxxxxxx) Where ‘xxxxxxxx’ is the RACF ID created for the DCDCONTL started task Then start DCDCONTL.
Feedback
thumb_up
Yes
thumb_down
No
