hi team,
In the Devtest portal when we are trying to use the "copy url" option to get the virtual service endpoint url we are seeing the issue. Please see the expected result vs the actual result:
URLl after copying : https://aaabbbc.com:9000/Adapter/MessageServlet?channel=
Actual url after copying: https://aaabbcc.com:9000/Adapter/MessageServlet?channel=:ABCC:SOAP_SEND_ATP
The values after : are missing.
Release : 10.6
Component : CA Service Virtualization
