ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
FDM masking using RANDBLOB function to mask the picture data in to oracle DB
Article ID: 187863
CA Test Data Manager (Data Finder / Grid Tools)
We are using RANDBLOB function to mask the picture data in to oracle DB. After running masking none of the records are getting updated in to DB.
Release : 4.8
Component : CA Test Data Manager
After copying required masking data images to C:\Program Files\Grid-Tools\FastDataMasker\BLOBS folder, Masking worked fine
