Model is blank for a family of devices in Monitored Devices
Article ID: 187839
CA Infrastructure Management CA Performance Management Network Observability
Model field is blank for a family of devices in Monitored Devices
All supported releases
The Model entry is derived from the sysObjectID OID value.  This is generally established during a certification via the certification team.  If it is displaying as blank that means there is no reference to the sysObjectID in question.  You can customize this by doing the following steps on ALL Data Collectors:
1. Navigate to /opt/IMDataCollector/apache*/etc or /opt/IMDataCollector/config/ in 25.4.4+.
2. Create a file named ModelMap.cfg
3. Enter your sysObjectID = Model name, for example:
1.3.6.1.4.1.9.12.3.1.3.1147=Cisco Nexus 7004
4. Save and exit the editor
5. Restart the dcmd service: systemctl restart dcmd
6. You can also validate this by accessing the following URL from the DC CLI:
curl -vk http://127.0.0.1:8681/debug/dispatcher/container/com.ca.im.data-mgmt.common/bean/modelmapcfg
7. Once everything checks out, rediscover the devices with the sysObjectID that you updated and within a few moments, the model name should be populated
