segrace problem -You are not allowed to perform this operation - AIX
Article ID: 187749
CA Virtual Privilege Manager CA Privileged Identity Management Endpoint (PIM)
The server always reads /etc/profile at login.
Segrace is called in the /etc/profile file to prompt the user X number of days before the password expiry
/sw/seos/bin/segrace -p -d 7
But, when a non-root user logs into the AIX 7.x release they get an error message immediately after login.
Last unsuccessful login: Wed Apr  1 23:55:12 2020 on ssh from 10.230.89.127
Last login: Thu Apr  2 00:27:10 2020 on ssh from 10.230.89.127
*  Welcome to AIX Version 7.2!                                                *
*  Please see the README file in /usr/lpp/bos for information pertinent to    *
*  this release of the AIX Operating System.                                  *
Release : 12.8 SP1
Component : CA ControlMinder
Operating System : AIX 7.x release
The user getting an message which is wrong, and this is a know issue.
We have a hot fix for this segrace problem - T52V245
The hot fix is attached to this article.
1587715359042__T52V245.tar.Z get_app
