ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Abend 4092 on return flow using ECI v1
Article ID: 187321
GenGen - Workstation ToolsetGen - Host EncyclopediaGen - Run Time Distributed
Experiencing an issue running an online CICS server getting a 4092 error. A group view is defined at 200. However when there are 33 or more rows returned in the view, get the 4092 abend. Middleware is ECI v1.
Release : 8.6
Component : CA Gen Build Tool, CA Gen Runtime Distributed, CA Gen Host Encyclopedia
Customer was running ECI v1 which does not support view flows greater than 32K. Gen development has completed coding for support of ECI v2 and is currently in Beta testing. Must limit flows to less than 32K until support for ECI v2 is released. Check the Technical Requirements for this info.
