User initiated exports are characterized as follows:
- any user of the organization can export flows in which they are members, including 1 on 1 flows
- the export includes a csv file of the entire flow history
- the export includes a JSON formatted file of the flow data
- the export includes images imbedded in the flows
- the export is a manual process only
- the user will receive an email with a link to download the export
The Enterprise export would be initiated by setting up a public/private security key by the Flowdock organization owner. This help page explains the process (
https://www.flowdock.com/help/enterprise_export). Enterprise exports are characterized as follows;
- require that the organization be licensed as Enterprise with a $9 per seat fee vs. $3 for a standard seat license of a non-enterprise organization
- the export does include all community flows as well as 1 on 1 flows in the organization
- the export is for daily only data for the prior 24 hours
- the owner or admin of the organization receives automated daily emails with a link to the download
