When the language is set / changed to Spanish (or anything non-English), the Help button does nothing when clicked. This may be reported in the Phoenix UI theme
STEPS TO REPRODUCE:
Expected Results: The expected behavior is the supported languages of
French
German
Spanish
Brazilian Portuguese
Italian
Japanese
will go to that language. If it is in a language we don’t support for localization it should default to English.
Actual Results: No pop up comes up as the HID and language doesn't match.
DE53998
Release : 15.7
Component : CLARITY STUDIO
Fixed in 15.8.1, 15.8.0.1, 15.7.1.3
Workaround: Go to http://techdocs.broadcom.com/ and find manually
