CA WA Agent and ESP: Jobs not running and ESP reports 'Transmitter Busy' or 'Agent notified'
Article ID: 186628
ESP Workload Automation Workload Automation Agent ESP dSeries Workload Automation - Business Agents (dSeries)
ESP or CA Workload Automation DE report some job states as 'Agent Notified'. Jobs may continue to complete, but WA Agent is unable to notify scheduler about the state.  Scheduler or manager may not be able to submit new jobs to the agent.  Restarting the WA Agent may only help temporarily and jobs may again go in READY or Transmitter Busy state.
Release : Any
Component : CA ESP WORKLOAD AUTOMATION, CA WORKLOAD AUTOMATION DE (dSeries)
OS: Solaris, AIX, Linux
The WA Agent may not be able to properly communicate with the ESP / DE.  The issue is likely related to UNIX message queue.
If a job shows any of these states 'Agent notified / Transmitter Busy' on the scheduler, then please do the following:
1.  Check to make sure the manager port is accessible from Agent machine.
Windows:  Run following command in Powershell
Test-NetConnection -ComputerName <manager_host> -Port <manager_port>
Test-NetConnection -ComputerName esp.example.com -Port 7005
Linux/UNIX
cat </dev/tcp/<manager_host>/<port>
cat </dev/tcp/deserver.example.com/7507
If port is accessible the command will just show a blank line.
2.  (Optional) Add a message queue
  • Shutdown the agent.
  • Navigate to agent install directory and remove rename database directory
  • Navigate back to the agent install dir and create a file 'msgqueue' using touch command.
  • Edit the agentparm.txt file and this line: oscomponent.msgqueue=/<path_agent_directory>/msgqueue
    • E.g oscomponent.msgqueue=opt/CA/WA_Agent/msgqueue
  • Save the agentparm.txt and restart the agent
  • Submit jobs and test
Note: The msgqueue file must be created in a directory which is accessible to agent and file should not be deleted. Do not create this file in /tmp directory.
