Problem logging into Clarity PPM over SOAP protocol and Xog
Article ID: 186183
Clarity PPM SaaS
we are having trouble with login to our Clarity PPM over SOAP protocol as well as Xog
We are using the PowerShell:
Invoke-WebRequest $uri -Method post -ContentType 'text/xml' -Body $SOAP
with the body: [xml]$SOAP = '
<soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/">
<soapenv:Header/>
<soapenv:Body>
<Login xmlns="http://www.niku.com/xog">
<Username>admin</Username>
<Password>' + $cappm_pwd + '</Password>
</Login>
</soapenv:Body>
</soapenv:Envelope>'
This login has successfully worked in the past. We are trying to find out what has changed since.
4:39
Component : CLARITY PPM
Security protocol type was TLS 1.0 which is not secure
The behaviour is caused by customer security settings in their environment
Customer updated their security protocol type from 1.0 to 1.2 and now they can connect without issues.
TLS standards keep developing and improving.
In general, anything that is using TLS standard below TLS 1.2 is considered to be non secure because these older encryption algorithms are known to be vulnerable.
