Automic Automation Engine - Support for SLES 15
Article ID: 185764
CA Automic Workload Automation - Automation Engine
SLES 15 (SUSE Linux Enterprise Server v15) is available since mid-2018 but it is not yet supported according to the Compatibility Matrix
Release : 12.2 / 12.3
Component : AUTOMATION ENGINE
At this moment SLES 15 is not supported, but Product Management will start working on this starting April 2020.
There no official date planned for the support of SLES v15.
Feedback
thumb_up
Yes
thumb_down
No
