Dublin Timezone Problems when using run_window
Article ID: 185747
CA Workload Automation AE - Scheduler (AutoSys) CA Workload Automation AE
Today a job that had been running normally for months encountered an error.This job is using the Dublin timezone, and we have previously encountered problems with this timezone
insert_job: jobname   job_type: FT
machine: machine-name
owner: autosys
permission:
timezone: Dublin
We created a test job and encountered the same errors with the Dublin timezone.  I then tried to schedule it with timezone: Europe/Dublin and it wouldn't insert:
CAUAJM_I_50323 Inserting/Updating job: TESTJOB
CAUAJM_E_10178 Start time is outside run window for job: TESTJOB
CAUAJM_E_10121 Failed to calculate 'next_start' for Job: TESTJOB
CAUAJM_E_10302 Database Change WAS NOT successful.
Using timezone: GMT+1 in the same test job allowed it to schedule and run correctly.
Release : 11.3.6
Component : CA Workload Automation AE (AutoSys)
Problem was related to the Operating System. Client informed the server team of the problem and showed them the zdump information.
The workaround solution is to update the jobs to use GB-Eire and it worked fine.
