A public hot fix is available for Symantec Data Loss Prevention 15.1, 15.1 MP1, and 15.1 MP2.
The hot fix includes important reliability improvements for the Enforce Server and for detection servers, for Windows and Linux. All 15.1.x customers should apply this hot fix.
The hot fix also addresses an issue on endpoints, in which Chrome 76 crashed on systems with the DLP Agent installed, for both Windows and macOS systems.
To apply the hot fix, download Hotfix_15.1.0205a.zip from MySymantec, and follow the installation instructions provided with the hot fix.
