cdm probe turns red and will not start nor write to the cdm.log.
Article ID: 182940
NIMSOFT PROBES DX Infrastructure Management
After upgrading the Primary hub to 9.0.2, the cdm probe will not start on the Primary. Other monitoring probes start and run without issue. View log results in ERROR: Not found and nothing is written to the log.
- The cdm probe had the cluster probe as a 'start_after' dependency but the cluster probe was deactivated.
Release : 9.0.2
Component : UIM - CDM WITH IOSTAT
The cdm probe had the cluster probe as a 'start_after' dependency.
The cluster probe was disabled during the recent upgrade and tagged as 'not required.'
Customer started the cluster probe, then the cdm probe, and it started without any problem.
<cdm>
   description = CPU, Disk and Memory performance probe
   group = System
   active = error
   type = daemon
   command = cdm.exe
   config = cdm.cfg
   datafile = cdm.data
   logfile = cdm.log
   workdir = probes/system/cdm
   start_after = cluster
   magic_key = 5PkrTDps+SfpaDiJ8wE6xeG17rH0gFlJosCXzayfm7L/1kmLkssxxxxBSA+Bf6VI
</cdm>
Related controller.log entries
Controller: START: probe_activate
Controller: probe_activate (cdm) from 10.xx.xxx.xxx/57792
Controller: ciOpen - cache path: F:\Program Files (x86)\Nimsoft/niscache
Controller: send_alarm - name = 'cdm' level = '4' metric= 'Can not start cdm, start after probe not enabled ()' token = '10.2:4'msg = 'as#controller.probe_dependency.2'
