ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
How does Purge Maintenance work in NS 6.0 SP2?
Article ID: 180397
Management Platform (Formerly known as Notification Server)
Question
Answer
Event purging section
In purge maintenance, these lines are run from the information stored in XML format. Also stored are the parameters that are set by you on the Purge Maintenance page (@Count, @Time). The parameter @Count is the value for "Limit computer events to [XXXX] rows". The parameter @Time is set two times. One for Purge Saved Reports, and the second is for Purge Resource Events.
delete from dbo.SavedReport where CreatedDate < @Time
exec spPurgeResourceEvent  'D0E33520-C160-11D2-8612-00104B74A9DF', @Count, @Time
exec spPurgeResourceEvent  'E81A4114-5D09-45DC-97F6-4B06F08C9AB0', @Count, @Time
This Purge Maintenance page can be found in the state column from the item table. This page information comes from the CoreSolution.config file. The stored procedure comes from the CoreDatabase.config file. Both files can be found under the Program Files\Altiris\Notification Server\Config folder.
The itemguid for Purge Maintenance is DE4A3A7C-2147-463E-8A06-A23B6C6E719B, so if you use the URL to see View as XML and replace the itemguid with this one, you can see the purge maintenance page.
http://<%NS Name%>/Altiris/NS/ItemAsXml.aspx?ItemGuid=DE4A3A7C-2147-463E-8A06-A23B6C6E719B
This SQL query will show you the event tables where the entries are being deleted from.
-- SQL query to show the event tables used in Purge Maintenance
select
vp.[Name],
ec.[DataTableName]
from [vEventClass] ec
join [vItem] it on it.[Guid] = ec.[Guid]
join [vProduct] vp on it.[ProductGuid] = vp.[guid]
where it.[ProductGuid] in (
order by it.[ProductGuid], ec.[DataTableName]
These are the results received when it was run:
Notification Server          Evt_NS_Security_Descriptor_Change
Notification Server          Evt_Push_Agent_Install_Service
Resource Management   Evt_AeX_Client_LogOn
Resource Management   Evt_AeX_Package_Server_IIS_Status
Resource Management   Evt_AeX_Package_Server_Package_Event
Resource Management   Evt_AeX_Push_Status
Resource Management   Evt_AeX_RapidInstall
Resource Management   Evt_AeX_SWD_Execution
Resource Management   Evt_AeX_SWD_Package
Resource Management   Evt_AeX_SWD_Status
Resource Management   Evt_Client_Transport_Status
Resource Management   Evt_NS_Client_Config_Generation
Resource Management   Evt_NS_Client_Config_Request
Resource Management   Evt_NS_Client_Pkg_Info_Request
Resource Management   Evt_NS_Event_History
Resource Management   Evt_NS_Event_Machine_Usage_Summary
Resource Management   Evt_NS_Event_Primary_User_Summary
Resource Management   Evt_NS_Event_Queue_Status
If you have a malformed purge maintenance page...
  1. Import the attached XML file called, "Purge Maintenance for NS6 SP2," but remember to change the extension back to XML. This is the safe method and requires that you have the permission to import an item
  2. Running the following SQL script will change the state column for the Purge Maintenance page. If you do not have the permission required to import an item, then this method can do, but this method is not as safe as the first choice. If you use this method, back up the database.
update item
set state = '<
item>
  <scheduling>
    <enabled>True</enabled><schedule><Trigger Type="1" Duration="0" Interval="0" KillAtEnd="0" Disabled="0" Description="At 2:30 AM every day, starting Wednesday, 1 January 2003"><BeginDate>2003-01-01 02:30:00</BeginDate><DaysInterval>1</DaysInterval></Trigger></schedule><sharedSchedule>{00000000-0000-0000-0000-000000000000}</sharedSchedule></scheduling>
  <purgeComputers enabled="True">
    <purgeType>Delete</purgeType>
    <duration>6</duration>
    <unit>Months</unit>
  </purgeComputers>
  <purgeEntries>
    <purgeEntry>
      <purgeConditions>Time</purgeConditions>
      <enabledPurgeConditions>None</enabledPurgeConditions>
      <count>-1</count>
      <units>Months</units>
      <query><![CDATA[ delete from dbo.SavedReport where CreatedDate < @Time ]]></query>
      <textRef>Delete Saved Reports</textRef>
      <textRefLabel1>Delete Saved Reports 1</textRefLabel1>
      <textRefLabel2>Delete Saved Reports 2</textRefLabel2>
      <textRefLabel3>Delete Saved Reports 3</textRefLabel3>
      <enabled>False</enabled>
    </purgeEntry>
    <purgeEntry>
      <purgeConditions>Time, Count</purgeConditions>
      <count>1000000</count>
      <query><![CDATA[
               exec spPurgeResourceEvent ''D0E33520-C160-11D2-8612-00104B74A9DF'', @Count, @Time
               exec spPurgeResourceEvent ''E81A4114-5D09-45DC-97F6-4B06F08C9AB0'', @Count, @Time
      ]]></query>
      <textRef>Delete Resource Events</textRef>
      <textRefLabel1>Delete Resource Events 1</textRefLabel1>
      <textRefLabel2>Delete Resource Events 2</textRefLabel2>
      <textRefLabel3>Delete Resource Events 3</textRefLabel3>
    </purgeEntry>
  </purgeEntries>
</item>'
where guid = 'DE4A3A7C-2147-463E-8A06-A23B6C6E719B'
Computer Purging
Computer purging is accomplished by a call to a .DLL and not a SQL delete statement. How NS determines what computers are to be purged is the use of a stored procedure spGetComputersToPurge. There is a SQL datetime parameter that is passed to spGetComputersToPurge, named @Time. The following is an approximate SQL query used by purge maintenance to determine what is to be purged.
/    This is an approximate SQL query used by purge maintenance to determine which agents have not reported in x days
/    Be sure to modify the @days parameter. The default is set a 30 days.
declare @days int
set @days = 30
select rx.[Name], cr.[Guid], dt.[LatestInventoryDate]
from [vComputerResource] cr
inner join (
            select [ResourceGuid], max([ModifiedDate]) as LatestInventoryDate
from dbo.ResourceUpdateSummary
            group by [ResourceGuid]
            ) as dt on cr.[Guid] = dt.[ResourceGuid]
inner join vResourceEx rx on rx.[Guid] = cr.[Guid]
where rx.[IsManaged] = 1
    and dt.[LatestInventoryDate] < dateadd(dd, @days * -1, getdate())
order by LatestInventoryDate desc
 But if you need to do the same thing by a script, the following can help you.
Note: This is an unsupported method
This is an nsscript and must be run in the Program Files\Altiris\Notification Server\bin folder.
The command line: NScript.exe %File_Name.cs%
// Delete Computers that have not reported inventory in 30 days
using System;
using System.Data;
using System.Data.SqlClient;
using System.Collections;
using Altiris.NS.Utilities;
using Altiris.NS.ContextManagement;
using Altiris.NS.ItemManagement;
class Class1
            static void Main(string[] args)
                        Altiris.NS.Security.SecurityContextManager.SetContextData();
                        using (DatabaseContext context = DatabaseContext.GetContext())
                                    string sql = @"
                                                            declare @days int
                                                            set @days = 30
                                                            select cr.[Guid], dt.[LatestInventoryDate]
                                                            inner join (
                                                            order by LatestInventoryDate desc";
                                    ArrayList list = new ArrayList();
                                    using (IDataReader reader = context.CreateCommand(sql).ExecuteReader())
                                                while (reader.Read())
                                                            list.Add(reader.GetGuid(0));
                                    IItem item = new Item();
                                    Console.WriteLine("Found " + list.Count + " Resources");
                                    foreach (Guid guid in list)
                                                try
                                                            item = Item.GetItem(guid);
                                                            Console.WriteLine("Deleting " + item.Name);
                                                            item.Delete();
                                                catch (Exception ex)
                                                            Console.WriteLine("Error deleting " + item.Name);
                                                            Console.WriteLine(ex.Message);
Purging Maintenance for NS6 SP2.txt get_app
PurgeEventClassTables.txt get_app
DeleteComputersFromTheNS.txt get_app
