Power Management or WOL (Wake on LAN)
Article ID: 179735
IT Management Suite Client Management Suite Server Management Suite Asset Management Suite
What is the criteria or process that is used in consideration for choosing a Wake on Lan 'relay agent' using the SMP Server?
ITMS 8.x
The criteria for selecting a relay agent are as follows:
First is to check and see if a computer has a role of SMP Server, Package Server (PS or Package Service), or simply the (Symantec Management Agent (Altiris Agent) is installed.
SMP Server is given a higher priority and then Package Servers and then down to just having the Altiris Agent installed.
Then is a check for the "ownernsguid" of the agent to see if it matches the SMP Server GUID in "VthisNS" view
The computer also needs to be managed locally  'IsManaged = 1'
An IP address needs to be retrieved from Inv_AeX_AC_TCPIP it cannot be Null, '0.0.0.0.0', or '127.0.0.1'
There also needs to be a valid subnet.  Not Null or '0.0.0.0'
The MAC Address is checked as well and cannot be Null or '00-00-00-00-00-00'
The Default Gateway cannot be '0.0.0.0' and the Subnet cannot be '255.255.255.255'
The tables Evt_NS_Client_Config_Request and Evt_NS_Event_History are checked for the most recent agent communication.
