How to block a specific IP using Network Threat Protection component
searchcancel
Article ID: 177730
Updated On: 10-18-2023
Endpoint Protection
You want to block network traffic associated with a specific IP address using the Network Threat Protection Firewall component of Symantec Endpoint Protection (SEP).
Edit the firewall policy associated with the clients to add a corresponding rule as follows:
Open the Symantec Endpoint Protection Manager (SEPM), click the Policies tab, and edit the Firewall Policy you wish to change
Click on "Rules" under the "Windows Settings"
Click on "Add Blank Rule"
Double-click or right-click>Edit the “Host” field, add a specific IP address so the “Source/Destination” IP is the address you wish to block, (Local/Remote is less generic, and requires the local address of the client on which the rule should be applied)
Double-click or right-click>Edit the “Action” field and change it from "Allow" to "Block"
Save and deploy the Firewall Policy as needed.
This will block all incoming and outgoing traffic associated with the specified IP address.
Note: You can also click on Add Rule and accordingly follow the procedure to make a Rule.
