Using Application and Device Control to limit the spread of a threat.
Article ID: 177628
Endpoint Protection Endpoint Security Endpoint Security Complete
Using Application and Device Control (ADC) to limit the spread of a threat.
Symptoms
There is a threat in the environment that is not being mitigated by the Antivirus functionality on the Symantec Endpoint Protection client.
The Application and Device Control feature is installed on the clients and functioning normally.
A suspicious file has been identified as a threat.
Please Note:
  • There are some threats that mutate and change the files that they use to launch infections. This behavior can change the fingerprint of the file. These steps may not be completely effective against all threats.
The first step is to identify the MD5/SHA256 hash of the threat. There are several ways to find this information.
Generating a fingerprint
Solution 1
The Endpoint Protection client comes with a utility called Checksum.exe. This utility will generate a file with MD5/SHA256 hash value for a specified file.
  1. Open a command prompt window.
  2. Start > Run > type: cmd > hit Enter or OK.
  3. Navigate to the directory that contains the file checksum.exe. By default, this file is located in the following location: C:\Program Files\Symantec\Symantec Endpoint Protection.
  4. by default: cd C:\Program Files\Symantec\Symantec Endpoint Protection
  5. Type the following command: checksum.exe outputfile inputfile
    • where 'outputfile' is the name of the text file that contains the checksum for specified file. The output file is a text file (i.e. outputfile.txt).
    • where 'inputfile' is the exact path to the file you want to generate the hash value from.
  6. The following is an example of the syntax you use: checksum.exe C:\checksum.txt "C:\Program Files\sample.exe"
    • In this example the command creates a file that is called checksum.txt in the root C: folder. It would contain the checksum of the specified file sample.exe.
Solution 2
Microsoft has a utility (now archived), called the "Microsoft File Checksum Integrity Verifier".
The utility can be downloaded here: Microsoft File Checksum Integrity Verifier
Solution 3
SlavaSoft has a utility called HashCalc that is freely available for download on the Internet.
  1. Download and install the HashCalc software.
  2. Run the HashCalc software from the All Programs menu.
  3. In the drop-down menus at the top select File for Data Format.
  4. In the Data field, click the "..." button.
  5. Navigate to the suspicious executable file and click Open.
  6. Make sure the check box for MD5 is checked.
  7. Click the Calculate button at the bottom.
Note:
Some of the tools used to generate MD5 hashes are 32-bit applications and due to Windows file system redirection on 64-bit Operating Systems, some unexpected behavior will occur.
If an application (like notepad.exe) is present in C:\Windows\SysWOW64 and C:\Windows\System32 folders, both the files have different hash values and it is recommended to add both hash values to the policy.
a4f6df0e33e644e802c8798ed94d80ea C:\Windows\SysWOW64\notepad.exe
b32189bdff6e577a92baa61ad49264e6 C:\Windows\System32\notepad.exe
Some MD5 Hash tools may provide the hash of the file from C:\Windows\SysWOW64\ though the user requests a hash for the file from the C:\Windows\System32\ folder.
Symantec’s Checksum.exe tool generates/provides a hash value for the exact file path requested.
Hash of C:\Windows\SysWOW64\notepad.exe will be provided if requested for C:\Windows\SysWOW64\notepad.exe Hash of C:\Windows\System32\notepad.exe will be provided if requested for C:\Windows\System32\notepad.exe
We would recommend using Symantec’s checksum tool for generating the hash values.
Configuring the Policy
Once the MD5/SHA256 hash is known, the Application and Device Control policy can be configured to prevent that specific file from launching on the clients and beginning an active infection. The following steps demonstrate how to create a new Application and Device Control policy to block the specific threat and assign it to clients.
  1. Log in to the SEPM.
  2. Click on Policies.
  3. Click on Application and Device Control.
  4. Under Tasks, click on Add an Application and Device Control Policy.
  5. On the top left click on Application Control.
  6. Click on the Add... button.
  7. Under Apply this rule to the following processes, click on the Add... button.
  8. Under Process name to match field, enter * (wildcard)
  9. Click OK.
  10. Click on the Add... button on the bottom left under Rules.
  11. Select Add Condition.
  12. Select Launch Process Attempts.
  13. Click on the Add... button on the right next to "Apply to the following processes:".
  14. Click on the Options>> button at the lower right.
  15. Select the Radio button for "Match the file fingerprint".
  16. Copy the MD5 / SHA256 hash into the field for the fingerprint.
  17. Check "Only match processes with the following arguments" and add an * in the box and select "Match exactly".
  18. Click OK.
  19. Next click on the Actions tab
  20. Under Launch Process Attempt choose "Block access".
  21. Click OK.
  22. Click OK.
  23. Next change to test (log only) to confirm that the file will be blocked. Once confirmed switch to Production to deploy this rule to production.
  24. Click Yes to assign the policy.
  25. Check the boxes for any group that the policy should be applied to.
  26. Click OK.
Illustrated Guide
An article has been created in Symantec's Knowledge will guide for the same. Block or log unauthorized software with Application and Device Control
