You are preparing to install a Symantec product on your Lotus Domino server. You want to know what considerations to take into account before installation.
In order to more effectively use Symantec products in the Lotus Domino environment, there are several things a typical Domino Administrator will want to consider before and after installation.
This document is divided into the following sections:
Prior to installation
Before installing a Symantec product in the Lotus Domino environment, Symantec recommends the following sequence to ensure a smooth installation:
Select an ID to run the agents Symantec products use
Before installing a Symantec product, choose an account that will run the agents used by Symantec AntiVirus/Filtering or Norton AntiVirus in the Lotus Domino environment.
The account chosen for this task can be either a user ID or a server ID. In either case, the ID needs certain rights for the Symantec product to work completely as expected.
Modify the rights of the selected account, if necessary
The ID selected needs to have the right to run unrestricted LotusScript/Java agents (in Domino 6, unrestricted methods and operations). Use the following steps to grant this right to the selected ID if it does not already have this right.
Lotus Domino 5
Grant the "Run unrestricted LotusScript/Java agents" right to your administrator or server ID.
Lotus Domino 6
Grant the "Run unrestricted methods and operations" right to your administrator or server ID.
Place the selected ID on the Execution Control List (ECL) or Administrative ECL
The ID selected in the first section must also appear on the ECL of the workstation the Symantec product will be administered from. Make sure that this ID has these rights:
Post installation considerations
After an ID has been given the correct rights on both the server and the workstation, the Symantec product can be installed.
Once the installation is complete, all databases created during Domino server startup should immediately be signed by the ID. Please see the document How to sign Symantec Mail Security for Domino databases for instructions on signing databases.
The Symantec product may now be used normally. However, it is recommended that, for security reasons, the Access Control List be modified. After installation, the Default access is Manager, and we recommend that access to the Symantec databases be limited.
