You need to move your Symantec Protection Engine (SPE) settings from one server to another. Protection Engine is the same version on both servers.
Because of certain cryptographic information that is stored in some of the configuration xml files and because the cryptographic information is unique to each SPE install, the configuration files (.xml) should not be copied between installations. You should use the settings from the first scanner as a reference to manually configure the second scanner. The process would be similar to the following:
We recommend creating a script using the xmlmodifier commands. This can then be used to quickly deploy settings on all necessary scanners.
Your Implementation Guide can be downloaded from the TechDocs document repository.
