The Symantec Endpoint Protection Mobile (SEP Mobile) application battery consumption is minimal and has a negligible impact on most types of mobile devices. The application battery usage details are available on the system settings screens and are usually under 2% of the total battery usage.
This article is to help troubleshoot when SEP Mobile is suspected of high battery consumption.
To investigate SEP Mobile high battery utilization, the host iOS Battery Usage statistics are required.
Please follow the instructions below in order to ensure that the screenshots contain the details which should allow support to analyze SEP Mobile battery consumption compared to the other running apps on the device, with the total background time, and other device health statistics, in an accurate manner.
