After creating a new PXE boot option and choosing to use iPXE the configuration is saved. The Use iPXE field is set to true at this point.
If an edit is performed on this PXE configuration the option to use iPXE is unchecked.
If the option to use iPXE is not checked again then the Use iPXE option is set to false.
Known issue
Deployment Solution 8.1 RU7
Symantec Corporation has acknowledged that the above-mentioned issue is present in the current version(s) of the product(s) mentioned at the end of this article. Symantec is committed to product quality and satisfied customers.
This issue is currently being considered by Symantec to be addressed in the next major revision of the product. There are no plans to address this issue by way of a patch or hotfix in the current or previous versions of the software at the present time. Please note that Symantec reserves the right to remove any fix from the targeted release if it does not pass quality assurance tests or introduces new risks to overall code stability. Symantec’s plans are subject to change and any action taken by you based on the above information or your reliance upon the above information is made at your own risk.
Please be sure to refer back to this document periodically as any changes to the status of the issue will be reflected here.
Please contact your Symantec Sales representative or the Symantec Sales group for upgrade information including upgrade eligibility to the release containing the resolution for this issue. For information on how to contact Symantec Sales, please refer to the following Web site:
