Does Ghost Solution Suite (GSS) support a multi-homed network configuration to install the GSS server server?
GSS 3.x all versions
Currently the Ghost Solution Suite Server does not have support for multi-homed servers. This includes servers with more than one physical NIC and servers with multiple virtual NICs supported through a teamed NIC configuration. GSS is intended to be installed on a server with a single network interface, and any other setup is unsupported at this time. Some environments and situations my function correctly but multi-homed servers that do not function properly may not be able to be properly troubleshot until they are configured in a supported manor.
Symantec Corporation has acknowledged that the above-mentioned limitation is present in the current version(s) of the product(s) mentioned at the end of this article. Symantec is committed to product quality and satisfied customers.
This issue is currently being considered by Symantec to be addressed in the next major revision of the product. There are no plans to address this issue by way of a patch or hotfix in the current or previous versions of the software at the present time. Please note that Symantec reserves the right to remove any fix from the targeted release if it does not pass quality assurance tests or introduces new risks to overall code stability. Symantec's plans are subject to change and any action taken by you based on the above information or your reliance upon the above information is made at your own risk.
Please be sure to refer back to this document periodically as any changes to the status of the issue will be reflected here.
Please contact your Symantec Sales representative or the Symantec Sales group for upgrade information including upgrade eligibility to the release containing the resolution for this issue. For information on how to contact Symantec Sales, please refer to the following Web site:
