ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
Ghost Solution Suite console does not resize correctly
Article ID: 171930
When maximizing the Ghost Solution Suite console it doesn't resize correctly and appears to be incomplete.
Currently unknown
Ghost solution Suite 3.2 RU6
Development is aware of this issue and is currently working towards resolving the issue.  If you'd like to be notified when the fix is available, please subscribe to this tech article and you'll be notfied via email when it is available.
