Known issue running Citrix XenApp and XenDesktop versions 7.13 through 7.18
Article ID: 171391
Updated On: 09-17-2019
Data Loss Prevention Endpoint Prevent
Files saved from Microsoft Office (using Save As) to client drives hosted on Citrix XenApp or XenDesktop 7.13 through 7.18 are not monitored.
However, if you are running Citrix XenApp or XenDesktop 7.14 or later with version 7.12 Virtual Delivery Agent (VDA), files saved to client drives (using Save As) are monitored.
Add the following registry key to Citrix XenApp and XenDesktop 7.13 through 7.18 endpoints to monitor files saved from Microsoft Office to client drives:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\picadm\Parameters
Type: REG_DWORD
Data: 1
