When there are Errors in the result of "ME show", or issues with Reports or anytime you do an Software Upgrade, you need to Reset the Measurement Engine.
Login to the PacketShaper CLI and enter the command
ME Reset
This will Reset the Measurement Engine and also will cause the PacketShaper to Reset.
