How much battery does Endpoint Mobile Protection use?
Article ID: 170790
Endpoint Protection Mobile
How will Endpoint Protection Mobile (SEP Mobile) impact my device battery consumption?
  • The SEP Mobile app’s battery consumption is minimal and has a minimal impact on any type of mobile device.
  • The app’s battery usage details are available on the system settings screens both on Android and iOS devices and are usually under 2% of the total battery usage.
