How to review the definition for TSSCAI
Article ID: 17079
Top Secret for z/OS Top Secret for z/VM
How to review the definition for TSSCAI?
Release:
Component: TSSMVS
Issue the following command to display location of the TSSCAI:
  CEDA VIW PROGRAM(TSSCAI) G(*)
Then select to review, example:
o Title
 OBJECT CHARACTERISTICS                                    CICS RELEASE = 0690
  CEDA  View PROGram( TSSCAI   )
   PROGram        : TSSCAI
   Group          : TOPSGRP
   DEScription    : CA-TOP SECRET Application Interface Stub
   Language       : Assembler          CObol | Assembler | Le370 | C | Pli
   RELoad         : No                 No | Yes
   RESident       : No                 No | Yes
   USAge          : Normal             Normal | Transient
   USElpacopy     : No                 No | Yes
   Status         : Enabled            Enabled | Disabled
   RSl            : 00                 0-24 | Public
   CEdf           : No                 Yes | No
   DAtalocation   : Below              Below | Any
   EXECKey        : Cics               User | Cics
