CA Detector running on same system as IBM Query monitor
Article ID: 17061
Bind Analyzer for DB2 for z/OS SQL-Ease for DB2 for z/OS SYSVIEW Performance Management Option for DB2 for z/OS Plan Analyzer for DB2 for z/OS Subsystem Analyzer for DB2 for z/OS
Is it possible to run IBM Query Monitor and CA Detector on the same system?
Release:
Component: PDT
The COMPAT option, which is specified in the highlvl.CDBAPARM(PDT) member, should be set to (Y). The default value is (N). Please note the explanation in PDT member:
COMPAT      (N)      /* Start Detector collections using an         */
                     /* alternate collection method that will allow */
                     /* Detector to run with other vendor's DB2     */
                     /* monitoring products.                        */
                     /* COMPAT (Y) should only be selected if       */
                     /* Detector has attempted to start a           */
                     /* collection and abended with a U120, or if   */
                     /* known conflicts exist between Detector      */
                     /* and other vendor's products.                */
                     /* Y - Yes, start Detector collections in      */
                     /*     third-party compatibility mode.         */
                     /* N - No, do not start Detector collections   */
                     /*     in third-party compatibility mode.      */
                     /*     display.                                */
It would be best to start Query Monitor first, followed by Detector, and stop them in the reverse order, but verify on a test DB2 first
