“System Settings: Optional subsystem” in the Machines datasource returns an empty value which cannot be evaluated using the current operators.
Article ID: 170011
Control Compliance Suite Windows
Windows platform schema binary is not able to recognize the special
value “{No Value}”.
CCS 11.5
An update to the code has been made in order to allow evaluation of special
value “{No Value}”.
Fix will be available in SCU 2017-2
A quick fix is attached to this KB.
Windows.Schema_Modified.zip get_app
