ALERT: Some images may not load properly within the Knowledge Base Article. If you see a broken image, please right-click and select 'Open image in a new tab'. We apologize for this inconvenience.
ProxySG Management Console does not load after upgrading to Java 8
Article ID: 168950
ProxySG Software - SGOS
Getting Connection Error - Error Connecting to SG
The CN in the default certificate does not match the URL used to access the Management Console.
Use the correct IP/hostname to access the ProxySG or create a new certificate with the desired CN name and assign that to HTTPS-Console service.
Reference HTTPS management console certificate - setup and troubleshooting
