In rare cases after a Check Point policy push, new flow distribution is unbalanced between VAP group members.
Symptoms:-
Chassis Resource Protection is enabled
Flow distribution becomes unbalanced after Check Point policy installation
The amount of processed flows is high
Uneven flow distribution persists over time
Example:CBS# swatch(option 9 - flowsched.swc)
AP Slot VAP Name NP1 Flows NP2 Flows Tot Flows
5 fw_1 115096 119097 234193
6 fw_2 112226 116137 228363
7 fw_3 186797 214955 401752
8 fw_4 185602 211963 397565
9 fw_5 186012 211493 397505
Total 785733 873645 1659378
Note the difference in the number of flows between fw_1/2 and fw_3/4/5.
