This article describes a rare problem that can occur when installing XOS using the Install Server or USBI.This article describes a rare problem that can occur when installing XOS using the Install Server or USBI.
The following symptoms characterize the problem:
1. During the XOS installation, the following error message appears:
/usr/share/fonts: failed to write cache
error: %post(fontconfig-2.4.1-7.el5.x86_64) scriptlet failed, exit status 1
Exec'ed program error
install-xos: rpm_install_release failed
2. The installation terminates at this point. After rebooting the CPM, the following error message appears:
GRUB loading, please wait...
Error 15
3. The boot process then freezes.
