Modules might attempt to boot from another chassis with the same system identifier configured.
The MAC address for the circuit IP addresses is a virtual MAC address that takes into account the system identifier.
An identical system identifier on two different chassis in the network can lead to duplicate MAC addresses on those chassis.
To display the current system identifier, use the following CLI command:
# show system-identifier
Configured System Identifier : 32
Operational System Identifier : 32
